I have a '72 Crestliner with a bad transom. I have already removed the wood between the two transom skins with a chain saw. The problem is that the inside skin was bad and I had to remove both upper corners.
I have made replacements L shaped 1/2 plywood that I plan on covering with fiberglass and resin to reinforce and waterproof them. I then plan on placing them on the inside(forward) side of the old transom skin then pouring a new transom with seacast.
My question is how do I attach the glassed wood to what is left of the inside skin of the transom ? Can I put glass/resin on both pieces then clamp the new piece against the old transom ? Will polyester resin adhere to itself ?
Thanks
Thanks
