I searched here and did not find too much information on this. I found information about sealing the holes but not much else. I figure I would use the largest bolts that fit which is 1/2 bolts. Should I put a renforcing plate on the transom and go through that or just go through the would and fiberglass and bolt on that. I was thinking about putting some kind of bar on the inside so the it has a larger surface area to pull on. Also should I have the bolts go from the inside out or the other way around. My boat is a 14ft Lone Star 15" transom and I am putting a 40hp 1986 evinrude on it. The transom is new and I do not think it ever had a bolt on motor. Bolts I was thinking high strength corrosion resistant from mcmastercar
