58 or 59 johnson 35hp super seahorse
tashasdaddy
Re: 58 or 59 johnson 35hp super seahorse
did you grease the splines, line up the water tubes, remove the spark plugs, so you can turn flywheel by hand, to line up splines.????? are you sure the drive shaft did not slip up, in the gear case.
coolguy147
im not sure how to line the water tubes up since there is two of them
tashasdaddy
they should line up side by side into the water pump grommets. you have several PM's.
tmcalavy
TD's right...you have to have good light and a steady hand, sometimes an extra one helps, too. You have to guide the water tubes into each one's grommet just before the LU slips up into place. Have the large retainer bolt ready to hold the LU in place.
coolguy147
well i figured out how to get the drive shaft up in the motor and seat it but i cant tell and see if i got all the water tubes in. i can look through the exhuast and see one water tube in from the motor down but the one from the water pump up i cant tell. and its very hard to push the thing up so that must mean that the water tube i getting in the way. what do i do? to get the water tube from the pump connected to the motor?
tashasdaddy
if the motor is on any angle it makes it harder to line up. you really need a helper to hold the lower, and a flashlight, and sometimes a butter knife, to slip in the crack and push the tubes.
coolguy147
lol a butter knife wow i would have never thought of that. well i was kinda doing it by my self though. u know after hold it for a while with ur left arm gets to hurt a lot lol. that thing is pretty heavy
tashasdaddy
about the 5th try, it gets real heavy.
coolguy147
ok today i got the lower unit back on and i made sure both water tubes were in before tightening down. well to chekc and make the top water tube was in i pushed my finger aorun dit amke sure it didnt move so there fore it was in its right place all i have to do is
get new fuel and air lines. fuel connector connector to the six gallon tank. and fuel line from the tnak to motor. oh ya and get a battery
tashasdaddy
what connectors do you need? i have some. do you have the 2 line fuel tank?
coolguy147
its a fuel pump connector so one hole
tashasdaddy
you can connect fuel hose directly to the motor, until, you get a fitting. i thought maybe you need the 2 line. for got yours have fuel pump.
coolguy147
yup gots a fuel pump and i replaced hte fuel pump diafram
coolguy147
ok i found the stuff i need for the fuel line and such its about 50 dollars excluding the fuel line inside the motor. ill stop by auto zone sometime and check them out on 1/4" fuel line.
well im am just so darn stupid. i forgot all about the key. well i didnt use a key when checking for spark. therefore that was why there was 1% to 0% spark on the motor. im am sheesh forgot all about it oh my gosh!!!!:(
well 2moro im using key and checking for spark. while finishing up connecting the shift rod and tell the guy about the fuel lines. so i masured everything under the hood its about 16-18 inches for all the items. im gonna buy 60 inches of fuel line and put 20 inches for each line since there is 3 lines. well to tell u the truth i might buy more just incase. oh and i might replace the line that leads to that safety deivce on the side of the motor
coolguy147
ok got ti started today and it ran like a dream.
i found out that i didnt put the water pump in right and so there almost overheated. i kept checking the cylinder by pouring water on it if the water steam off which in fact it did. thereofr ei shut the motor down and put everything away. well i found out that the water tubes should be both ceoming from the motor but i didnt think about it but mine has one going up and one coming down. its like impossible to get em both in. 2moro or wednesday i will most likely work on it.
for some reaosn my primer bulb liek didnt work or something but after i added gas it was better and then it started
coolguy147
ok my next step is to get the flywheel off. i got the harmonic balance puller and everything.
all i need to know is what kind of screws and washers do i need to get?
can u give me that site with all the part numbers cause i need to get more coils points and condesors:D
