skydiveD30571
- Feb 13, 2012
- 1,042
volvo penta 5.0 gl-h
It was idling a little high the first time out a few weeks ago (about 800-900rpm), but otherwise ran great. Took it out yesterday after i did cap/rotor/plugs/wires, tweaked idle speed screw, and replaced a leaking exhaust boot. It now has an intermittent idle issue.
On the driveway with the hose it choke started great and idled steady at 600rpm for 10-15minutes. I thought, "awesome, we got the idle speed just right." Then rpm's started bogging down and returning to 600, like it was starving for fuel. In a hurry to leave, I shut it down and trailered it out.
Once in the water, at first it idled fine, but after half an hour or so it usually would bog down and fluctuate from 200rpm to 600rpm. This seemed more common after a load was put on (i.e. pulling a skier). Throttling back to idle it would immediately bog down to 200rpm then back up to 600, taking about 1 second per iteration. It was a constant rythym when doing this. Many times at the low rpm side it would stall out. By the end of the day, it needed throttle everytime it started to continue running, and would usually stall if left in idle for more than a few seconds.
It is hard to explain because it was so hit-and-miss throughout the day, but it definitely got worse as the day went on. So the first 30 minutes of the day it was basically fine, and the last hour or so it consistently bogged down and stalled only at idle.
Also, once out of idle, it runs great all the way thru wot. It is definitely only at idle (both neutral and in gear). I tried searching for forums, but most people with a bogging issue have an engine that idles great then bogs down once given throttle. Mine is the opposite.
At first I was thinking a fuel issue on the boat side, but I got to thinking, wouldn't that affect the whole rpm range not just idle? Being that during choke start it idled great, it seems almost like a lean idle once the choke is fully open. Any ideas? I don't think a carb rebuild would hurt, but I'd like to pinpoint the issue to the carb before forking out the money or attempting it on my own.
