Boat won't start, just clicks
DaveRR
I've had the boat winterized and it sat in the garage for the winter. I've never used this boat, because I bought it very late in the Fall. I charged the battery and put the two wire connectors on the + and _ poles. The two ground wires are tapped on the large battery poles. I turn the key and all I get is "clicking".
90stingray
Re: Boat won't start, just clicks
Make sure motor is not locked up by turning over manually. I would also pull the starter and have it tested... they do get corroded. If you are taking the starter in to be checked you can have the battery tested too. Check the battery cables at the battery, and the starter. Both positive and negative leads. Good place to start.
Ayuh,... It's probably corroded wiring connections,...
They're ALL suspect, both positives, 'n Grounds..
Remove, sand, clean to Shiney metal, reinstall, 'n grease 'em to stop the corrosion...
If cleaning the wiring connections don't fix it,...
Load test the battery...
