Boat with Yamaha 115 pulls to the right
jdsg
I have a Yamaha 115 (circa 1998?) on a 19 foot Seastrike. The boat pulls very hard to the right. We have tried adjusting the anode but have had no luck. Are there any other tricks I might try.<br /><br />Thank you
Booner
Re: Boat with Yamaha 115 pulls to the right
Welcome to iboats jdsg <br />Quote by jdsg<br />"We have tried adjusting the anode but have had no luck."<br /> Did you mean the trim tab? Turn the rear end of trim tab to the right (starboard side)
douglloyd
As you get on plane trim out the motor until you get a more neutral steering response. When you get it high enough it will feel better.
jdsg
Originally posted by Booner:<br /> Welcome to iboats jdsg <br />Quote by jdsg<br />"We have tried adjusting the anode but have had no luck."<br /> Did you mean the trim tab? Turn the rear end of trim tab to the right (starboard side)
jdsg
I may be calling it by the wrong name, but I assume it is a zinc at the bottom of the motor which has a small fin. I have no trim tabs (unless there is something on the engine). Thanks for the help
jdsg
Originally posted by bluebird:<br /> As you get on plane trim out the motor until you get a more neutral steering response. When you get it high enough it will feel better.
jdsg
Do you mean to raise the motor or is there some other adjustment I can use. I have no trim tabs (unless they are on the engine and I don't know about them)
douglloyd
The motor should be equipped with power trim actuated by a switch on the throttle/shift control. It says up down on it.
Dunaruna
Originally posted by jdsg:<br /> I may be calling it by the wrong name, but I assume it is a zinc at the bottom of the motor which has a small fin. I have no trim tabs (unless there is something on the engine). Thanks for the help
That's it. That is the devise to counteract torque steer. <br /><br />They are called by many names - zinc, tab, little rudder thingy.........<br /><br />Turn the trailing edge ( the bit closest to the the rear) in the same direction of the pull, that will counteract the pull and should straighten you up. Sometimes it takes a few adjustments to get it right.<br /><br />Aldo
jdsg
Originally posted by bluebird:<br /> The motor should be equipped with power trim actuated by a switch on the throttle/shift control. It says up down on it.
jdsg
Do you mean that by raising the engine I can reduce the pull to the right?
ivar
Does your engine have power trim? <br />If so, the steering torque will change as you trim out the motor.
31900
jdsg, one thing at a time. Dunaruna has got the answer. Sort that out first and then concentrate on trim.
