boat wiring
55owens
Hello ,I have been given a 1955 owens with a evinrude 100, boat is in grait shape for its age and outboard works, but wiring is a mess need info on boat and wiring
5150abf
Re: boat wiring
If the boat is a '55 I would almost guarantee it has been rewired several times.
Boats aren't like cars where you can get a manual with a wiring diagram, you will just have to start pulling wires and replacing them.
normally when someone adds or removes something to a boat they just cut the old wires and let them lay which makes a mess.
When I redid my boat I had a 5 gallon bucket of old wire.
achris
More fish than mountain goat
Re: boat wiring
The quickest, cheapest and easiest way to re-wire boats is to remove the battery from the boat... then remove every wire that isn't part of the engine-control box harness and start again....
Get yourself a few metres of 6mm red-black sheathed cable and a couple of terminal blocks... Mount the blocks under the dash (or any other convenient location), run the red-black from the battery (or battery isolator switch) up to the terminal blocks and then run everything else (on fused cables) from there.... Neat, tidy, easy to add extra equipment and dead easy to fault-find in the future... Which you will probably never need to do because being neat and tidy makes it reliable :D:D:D
Chris.........
Re: boat wiring
At the very top of the electrical forum is a sticky titled "Generic Boat Wiring Diagram by Silvertip". It should help you get the job done. In 1955 the manufacturer probably didn't have a wiring diagram. They just ran wire and hopefully everything worked.
