Boat tilts on its side harder than the other ?
tunerauto
Boat - 72 Glastron V153 15' - restored with 2 6 gallon gas tanks under the front bow and 1 battery on back right side.
Motor - 65 hp Mercury 650 longshaft with ding free prop and clean skag and attwood hydro fin - completely centered
When going at medium to full throttle when I turn to the left the boat leans SUPER hard on its side which is often scary.
When doing same speeds and turning right , the boat corners nice and flat like its on rails.
Each time it has been with me 170lbs driving , the lady 140lbs in the pass seat front and my 70lb son in a tube out back.
It also does it when nobody is behind the boat and I have all bodies inside the boat properly positioned so as weight distribution is perfect.
Any ideas ?
Hull is completely empty of water and dry .
ezmobee
Re: Boat tilts on its side harder than the other ?
First thing I'd do is ditch the hydrofoil and see if the problem goes away.
tunerauto
it did this before adding the hydro foil. I added the foil to see if it would correct the issue and it didn't. also the foil did not make it any worse either.
crownlover
check the scag and make sure its not bent from left to right. i had one doing the same thing. Used a rubber mallet to put it back in line and my problem was fixed. good luck
