Boat suddenly died won’t turn over and no trim
Status
Not open for further replies.
Waterwayne
my stingray died now won’t turn over and no power to trim system any help would be great
Ayuh,.... Start at the battery, is there 12v there,..?? Are the terminals, 'n cable ends shiny metal Clean,..??
Next is the starter, 12v there,..??
Waterwayne
Yes sir 12v at battery and starter ignition also good I can short the starter solenoid and turns over the fuses at the motor fuse box doesn’t seem to have power on them touched with a light no fuses have power
alldodge
Check for power on both sides of the 50 amp breaker.
The click can be a bad connection or a bad starter relay
Waterwayne
I removed those relays and tested where they plug in got like I didn’t get 12v there was like .50 or something
alldodge
do have power on both sides of that breaker
You have a broken connection or another fuse/breaker somewhere. Looking at the wiring diagram, there is a direct connection between the 50 amp breaker and the relay
alldodge
Thanks the wiring diagram you posted is it for glp-e 3.0 engine
Its for a GL-E V8 model and don't know what the p indicates. Have GL-A thru E 3.0 and 4.3 and all show variations of the same connections. Sensor added or removed, but power connections are the same for the most part
jerryjerry05
Some boats have a fuse panel under the dash?
For some reason they wired it the ignition system(maybe not your boat)
Test the fuses.
Status
