Boat stuck in neutral
JMyro
I have a 1991 120 hp force L drive...I took the boat out today and everything ran fine. I parked it for a bit and then went back out. 5 feet from the dock on my way out the second time, the engine was stuck in neutral. When I tried to give it gas the engine just revved and we didn't go anywhere. We started floating towards the shore so I trimmed the leg up. We paddled to deeper water and then the leg wouldn't trim down. When I push the trim up button on the throttle it goes up but when I push the down button I just hear a click from the engine compartment. Does anyone know what is happening here!!!!!!
pnwboat
Re: Boat stuck in neutral
Sounds like you've got two separate problems here. As far as the neutral issue, make sure the shift linkage rod at the lower unit is moving when you move the throttle from Forward to Reverse. Not sure what your lower unit looks like but the small rod in the picture moves up and down to shift from Forward, Neutral, and Reverse. Normally you can only see the top 2 inches or so of the rod. Might help if you can provide a picture of your lower unit so that we can tell what type it is, if it doesn't match the picture below.
Force 75HP 85HP 90HP 115HP 125HP Outboard Motor 20" Lower Unit 75 115 125 HP | eBay
NOTE: Make sure the throttle handle is not in the Neutral Fast Idle position. If it is, this will disengage the cable that moves the gear shift linkage and you won't go any where when you push the throttle forward. To get it back to engage the shift cable, pull the throttle handle all the way back into full reverse, then back into Neutral. If it was in Neutral Fast Idle, the handle will "click" and you're back to normal operation.
Take a look at your trim relays to see if they are fully seated. Might try reversing them to see if the problem is the relay themselves. This is what the relay itself looks like.
http://www.ebasicpower.com/c/graphics/00000001/CDI852-9809.jpg
This is the relays attached to the wiring harness. They just plug in. I'm sure that there's a good chance that your wiring hatness doesn't look exactly like the one shown, but the relays and the way they're attached should be similar.
http://www.greenbayprop.com/images/products/fa663744_1.JPG
JMyro
So I have taken the boat back to the water after I adjusted the control on the throttle. The leg trims up and down just fine now, I think it was just stuck in the up position and needed a little force to get it back operating again. I can get the boat into reverse now no problem but forwards is still not working. I will keep updating once I learn more. Maybe it just needs some more adjusting?
JMyro
I broke down and took the boat to a marine mechanic. It seems my lever that shifts into gear was hitting the bellows exhaust so it wasn't travelling far enough to go into gear. Probably the wrong lever for the boat. Anyways he made a few adjustments and it seems to be working ....so far....thanks for the help!
