Boat stalling issues. please help!
blingleng
Hello guys i am a rookie to boats and jus recently bought a used 16 ft aluminum fisher bass boat with a 60 hp mariner outboard motor....
Boat was ruuning ok when i first bought it but now i am having alot of issues with it....
1) stalls when i take it out of choke.
2) when it dosent stall out of choke and I try to put it into gear it stalls then has a hard time starting back up... but if it does start back up in choke when i take it out of choke it will die again... again.. and again....
So far i have replacd the spark plugs thinking it would help and it has help to start right up but still having the same stalling issue.
Ive been told to adjust the idle control valve, and clean the carbs.... But where are these located? The boat came with no motor manual....
Any help will be much appriecited.
Thank You all.
Leng
