Boat spcs
ptomlin
Hi I just bought a 1999 larson 206 lxi and was wondering were i could find out how big the gas tank is.The owner doesnt no were his books are.Also when I went and filled it up at the gas station when it clicked off and I removed the nozzle from the tank gas srayed out all over the back of the boat.Is this normal and how can it be avoided?Thanks for the help.
Thad
Re: Boat spcs
There should be an access plate on the deck somewhere under your bench seat. If you open that you should be able to see where the fuel lines attatch to the tank. In this area there will be a mfg plate. It will have the size of the fuel cell on it.
As for the fuel spilling, I am not an expert, but it sounds as if maybe your vent line may be obstructed. Or, you pulled the nozzle out to quickly.
Mine will have a little overflow as it shuts off if I do not pay attention.
But it does not spray out.
Someone with much more knowledge than me will have an answer for that one:)
ptomlin
Re: Boat spcs
Thanks for the help I will look for the specs there.I did not pull it out to quickly"that just sounds wrong dont it" it had clicked off before I removed it and it suprised me .Thanks again for the help.
