Oldhillbilly
Thread starter- Joined
- Jun 15, 2015
- 4
Hi there. I recently got a little bowrider runabout. It is a 1996 Larson Flyer 166. Has a '96 Johnson 90hp J90TLEDA v4 2 stroke with 137 hours. The recommended rpm range on it is 5000-6000 rpm and I had heard it was usually best to be near the upper end of the rpm range for best overall performance. Boat, motor, gas, oil, and me is about 1650-1700 pounds and at heavy loads about 2300 pounds. It came with two propellers, both of which seem too big to me. One is an aluminum 14x17 3 blade that I haven't figured out the brand on. The other is a 3 blade stainless Ballistic 13.5x17.
The aluminum prop runs about 5050 rpm at about 38 mph lightly loaded with good acceleration. Heavy load drops it to about 4900 and 35 with lackluster acceleration
The stainless runs about 5000 rpm at 40 mph light with okay accel but not quite as good as the aluminum. Heavy sees about 38 mph at 4900 rpm with poor accel.
I will use the boat mostly on Table Rock lake in sw Missouri. It is a good sized lake where sometimes it is nice to cruise somewhere 50 miles from where you start so decent cruise efficiency and top speed would be nice. But most of the time the boat will have about 3-4 people on it and do lots of toy pulling within a few miles from the dock. I wouldn't be against having two props of the right sizes if there was enough advantage to be worth swapping props for different uses but I am hoping to come up with a prop that is good enough all around to not have to bother unbolting them.
So any recommendations for the best overall prop or the ideal props for my specific uses would be greatly appreciated. I would be happy to try and provide any further info needed.
Thank you.
Thank you.
