Re: boat paint
Interlux Perfection is designed for roll and tip. It is a 2-part poly urthane that is very good. This paint is basically Awlgrip with brushing additives added to it. The downside is that it is very expensive. Good color selection.<br /><br />Interlux bright sides is a one part paint that is a little softer than a 2-part paint, but will also give good results. Good color selection.<br /><br />If you want a good water based product, you can go with System Three's 2-part polyurethane. It too is designed for roll and tip, but it has limited color selection and results in a semi-gloss finish unless you apply a clear coat.
