Hey everyone, I have browsed on here quite a bit over the last 2 yrs but have never posted. This year I took my boat out (21' 91 bayliner with a 4.3 Mercruiser V6) for the first time and everything was great, started, ran hard, etc. However, the second time I took it out, I can no longer to get it to come up on plane unless I am the only one in the boat.
WOT is only reaching about 2800 RPMs, when it should be at 4300+. Running in neutral it revs fine, though I know this doesn't mean much. It does not seem to be running rough and idles fine.
So far I have replaced the water separating fuel filter, checked the gas tank vent, checked the anti siphon valve for any corrosion or blockage, checked distributor cap and rotor, pulled spark arrestor off and tried running without it, attached a vacuum/pressure guage to fuel supply and tested, however so far only with muffs on, but will be taking it out to test tonight. Following these instructions (http://forums.iboats.com/showthread.php?t=283363) I received a reading of 4 almost 5 in. of Mercruy as far as resistance goes which seems a little high, but not too sure. When I pinched the line before the guage the pump was able to provide 10+ in. of Hg of vacuum.
I have never had any issues with this boat in the year and a half or so that I have owned it now. Any ideas? Next steps? I don't understand why this would suddenly start. Also, this boat is trailered and used on local lakes.
Thanks in advance for your help!!!
