Re: boat newbie needs motor help
No that I know but I ment to say was a new gen alpha that is a little better than the old one that might hold up to the more hp that I am looking for
Ayuh,... Updatin' an Alpha from Alpha 1, to Alpha 1, Gen.II is mostly a change in the shifting system/ linkages, 'n redesigned waterpumps....
No real efforts or changes in the structual intergerty of the drive,...
Still rated at 300hp, as it pretty much has been since the old Model 1 drives of the late 70s...
The Biggest Difference in choosing a transom assembley/ drive Alpha 1, Vs. Gen.II is the point in which All of the Alpha sieries interchange,
Easily, with each other...
Basically, it's Everything up to 91 interchanges with each of the various names it carried over the years...
After 91,... Your choice of replacement/ repairs is the Gen.IIs only....
Either Way,....
Slap a Fire-breathin' 383 in there, 'n Go Boatin'.....
Either of the Alphas can be replaced at under $1500. a Pop.... Who Cares,...
They're replaced, Cheaper than can be repaired....
