boat leaning to th left
sais357
hello i have a 1988 sea lion center console boat 92 johnson 70hp boat runs real good had the motor rebuilt a month ago i was out in the water on day and the motor seemed like it was going to come loose from the boat took it back to the place that rebuilt it they said the motor mounts were bad so they fixed them i got boat back took it out and no matter what i do its leaning to the left can some on please lead me in the right direction to remedy this problem again it wasnt doing it before they fixed the mount
D
DJ
Guest
Re: boat leaning to th left
Is the engine straight on the transom?
sais357
yes the engine is straight it was fine until i took it to the shop to have the motor mount replaced
RPJS
Have you checked the trim tab.<br />Its located on the underside of the ventilation plate just above the prop.<br />If its damaged or missing it will cause your problem.
