Boat kicking back at WOT
Evinrudetrue
Ok I really need some help here I have a 1984 evinrude 150 horse 6 cylinder V6 model number E150ANCRS and this past weekend was on the lake and the motor would run good at 30 MPH and the tach was at 3000 which is normal as soon as I went to WOT at 5000 RPM it would kick back as if I pulled the remote controls back.The boat would plane out just fine and run at WOT for just a few seconds and cut back. Once it cut back it would literally kick back upto WOT then drop back down. I'm at a loss here on this one. Just need some good advise to trouble shoot this problem starting with the easer stuff first and then I can tackle the harder stuff. Any help or advise on this matter or if anyone else has experienced this problem would really like to know what you did to resolve it.
daselbee
Pump the primer bulb when the fault is happening. You are acting as a manual fuel pump.
If it clears up, the fuel pump is bad.
emdsapmgr
Do daselbee's fuel test first. If it tests ok, then check next for a weak ignition component. Not unusual for weak components to suddenly crap out once the engine heats up to normal operating temps. An automotive timing light is helpful here. If you can isolate the problem to weak spark on one head or the other, you can swap power packs and see if the problem moves to the other head.
boobie
One thing about the timing light. Turn it around and look into it for black spots. That's where the ignition miss is.
