FrankBama
Thread starter- Joined
- May 26, 2009
- 7
My boat has no power anywhere after I just replaced my ignition switch. It is an OMC ignition switch for a 1989 Johnson 140 outboard. It was working fine just before the swap as I tilted the motor. I replaced the wires terminal by terminal to ensure that I did not mix anything up. I did not disconnect the battery before doing the work as I suspect I should have and while swapping the switches I think I heard the crackling of electrical current. Have I shorted something out? I checked all fuses on the dash and they are intact. Any help would be greatly appreciated! Thanks!!
