Thalasso
- Jan 18, 2011
- 2,879
Re: Boat has me paranoid.. can't even enjoy it
It appears you have all the major and expensive items repaired. Go out and enjoy the boat. You/yourself is the only thing making you crazy. Not the boat.If you put the bellows on right it wont pop off.Start feeling good about yourself and the things you have accomplised with your repairs. That alone will give you a differant perspective.You will know that you will be able to handle any more repairs
Heres a list of some of the things I've replaced. I've done a ton of other little things as well.
NEW TRIM PUMP, NEW BELLOWS, NEW IMPELLER, NEW SHIFT CABLE, NEW starter, new Carpet, new seats (front & rear totally custom), new floor around ski locker(little soft everywhere else very strong), new pedestals, new boat cover, new window supports, NEW Battery, NEW trailer tires, smart tabs installed, new stereo, new cig lighter, 2nd bilge pump installed, New LED nav. lights, new fishing pedestal up front, new custom steering wheel, new bilge fan and led switch, new horn button, new trim switch in new location, new folding rear seats which can be placed higher and used as sun pads. blue padding installed on swim deck, new bilge vent covers (others were broken), fixed a broken starter mount with a proven method holding 5 years strong on other boats (bought it broken without knowing, did this fix and its been stronger then when it came off the line), Storage net on side wall, vinyls all cleaned and painted, new spark plugs (also checked for signs of water in cylinders, they look good)
I just know I'm going to put this thing in the water and my gimble bearing is going to go, my engine is going to hydrolock somehow, or one of my bellows is going to pop off and sink me before I can even get her out of the water. Thats all I can think about happening.
