Boat guild brackets
Ryanpm6774
okay, so I have just purchased from an auction website PVC trailer boat guides. They are awesome! However, I want to mount them to my boat but don't have the hardware. I called the manufacturer, and they don't sell just the hardware. Does anyone have economy Fulton trailer boat guides that can give me either measurements or a place to find the hardware? Thanks.
midcarolina
What hardware you need will depend on the width/depth of your trailer beams, measure the beams add the diameter of the post, then either go to auto parts store see if they have shackles to match or get some all thread and make your own......then all you need is some plate for the ends of the shackles.
airshot
In your post you mentioned mounting them to your boat, I hope you mean mounting them to your trailer... As mentioned you should be able to create something and find hardware at you local hardware store.
midcarolina
In your post you mentioned mounting them to your boat, I hope you mean mounting them to your trailer... .
That is a complete waste of server space, and is about as annoying as someone replying to a post to point out a typo or a spelling error........
:mad:
Starcraft5834
check Eastern Marine on line for parts, they might have something.... or call them....they likely have parts laying around loose, maybe they will sell them to you
kjsAZ
are these the single pole Fulton ones? They are usually mounted with just some U-bolts around the trailer frame.
Starcraft5834
I use similar guides..a must have for ease of loading..tried it for half a season without em.. what a hassle. With guides what a difference. .
