Boat flooded, electrical help please
PAAMORE
My Husband left the plug in and after several days of rain, we realized the boat was full of water.
We have since had it on the water...motor fine, as well as the tilt and trim and trolling motor. However Fish/depth finder,
ilge, lights andaereator will not work. we replced the fuses, still no go... please use words that I will understand, thank You kindly. Bass Tracker 07, I think.:facepalm:
Don S
Re: Boat flooded, electrical help please
Sounds to me like you have lost main power to the accessory panel. Did you check for fuses at or near the battery for fuses/circuit breakers?
PAAMORE
Thanks Don actually just checked and those fuses were corroded, so Hubs has gone to get new fuses for there, fingers crossed, appreciate the quick reply friend. I'll let you know.
PAAMORE
Okay so we changed out the two fuses near the battery...and in circuit box....still no power, any other ideas please?
Wind dog
Got a test light or volt meter handy? Start testing for voltage, start at battery & work out from there.
does the bass tracker have a switch labeled master and a white push button breaker down near the right of the seat? if it has the switch turn it on and off and few times and make sure the white buttons near the seat are pressed in. after that im afraid you will need a test light or a volt meter to find the problem as this may be a corroded or bad connection after it got wet.
PAAMORE
I haven't checked yet, but i will be able to work on it this weekend, thanks for your reply, when I find the culprit, i will let everyon know, so that it might help someone else. In the meantime if anyone has anything to add, ope to all suggestions thank you!!!
PAAMORE
will check this weekend...Thanks
JASinIL2006
Don, that is very neat. You make great tutorials! I've bookmarked it for future use. Thanks.
Jim
