My "new" boat - '74 welded alum. Fisher Bass Bateau w/ 18 hp Evinrude - seems to leak either THRU the plug (regardless of using new "snap-fit" kind or "T-handle" screw-in kind) or right around the drain hole itself. I can see no crack/pinholes around the drain hole from either under the hull or on the transom end itself. What's up?!? Other boats I've been in seemed to take on "token" amts. of water but not as much as this - 2 people sitting at rest fishing shouldn't have to start up the engine and open up the thottle once an hour to drain the boat! A. Is this normal? B. How could I isolate what seems to be a leak? C. How would I make it stop? <br />Part of me wants to just cake JB Weld or the like all around the drain hole on the inside but then I'm left w/ trying to remove it if it doesn't work! Squirt silicone caulking all around it and hope for the best?!?!
