wesleycharlessmith
Thread starter- Joined
- Jul 13, 2017
- 9
Hello Everyone, long time lurker and first time poster. I have a 1986 Bayliner Capri with a force 85 motor that I assume is the same year as the boat. I just got the boat and am having a little trouble with it. The problem is when I am out on the water the boat will go fine at low to about half throttle but when I go wide open the boat sputters and ends up stalling out. I have cleaned the carbs and put new seals in them. I checked the compression and all three cylinders are at about 125#. The boat has fresh fuel. I am using a 50:1 mixture with Penzoil marine 2-cycle oil. I pulled the fuel pump diaphragm and there appears to be no holes in it.
My question is about the two screws on the outside of the carbs. The ones where the air box attaches I pulled out and cleaned. I then adjusted them as recommended on this site to about 7/8 turns out from lightly seated. There is another screw on the outside that I think is the air screw, is that the correct term? I cant find anywhere on how to adjust this one so I have not taken it out to clean it. Is it possible that this may be gunked up causing part of my problem? Can someone please tell me how to adjust this screw so I can take it out and clean it. I have a Seloc manual but I dont see in there anything about this adjustment.
