I've seen a lot on this topic here.Be Aware.<br />If you have to push your ignition key in to attach the lanyard (kill) teather clip.Start the motor as normal.It should start as normal.PULL the clip.It should stop running.Turn the key (with lanyard off) Started,didn't it.<br /> All the newer ignition switches turn the key counter-clockwise to shut down the motor.No ground signal is sent to the power pack.It is a manual device.<br />DHP
