Bluewater inboard parts from Iboats?
Fishermark
Re: Bluewater inboard parts from Iboats?
And the question is..... :confused:
What parts are you needing?
You might try looking in the sterndrive section instead of the inboard section.
Tahorover
So your saying all the parts from a 454/bravo are going to fit this inboard? I just got the boat yesterday and it has not run in two years. I'm going to need a bunch of stuff and didn't want a hassle/cost returning parts because I assumed the bravo and bluewater were the same.
Fishermark
No - I didn't say that. I asked what parts you are needing. It was more of a suggestion on my part to look under the sterndrive section to see if your engine was listed there.
Depending upon what part(s) you need, many will be the same for a similar year Mercruiser 7.4 engine. But, no, I am not familiar with your particular drive set up.... someone else will chime in soon I am sure with additional help.
Don S
About 99% of the engine parts for the inboards is the same as the I/O parts.
As Fishermark mentioned, it depends on what you are looking for. Basically,iboats sells aftermarket parts for any of the engines, as they are not a dealer for any of the inboards you list or for Mercruiser IO's.
If you are looking for tuneup parts, manifolds, carbs, kits, impellers and the list goes on, then look in the IO section under Mercruiser.
