blue prints
michael forbes
hi i have a 1982 sea ox 200c that i am in the process of restoring basically all of the wood is rotted out and i cant get an accurate measurments for the height of the stringers or floor in the cabin. can anyone help me please
Re: blue prints
Ayuh,.......
Install a String Line at whatever Points you're trying the Measure,+ Measure From that.......
Measurements can be taken every foot, or every 1/2 foot, or whenever needed,.....
Then just plot it out on the New Wood......
Tail_Gunner
Re: blue prints
As Bondo stated, one thing to remeber there is not a square line, joint or seam in boat. A chalk line will get almost any line right point to point and a tape measure just to balance it all out. In the end you just bond it together with eyeball and luv.......:love:
Dont forget a good angle grinder, a almost Indispensabe tool.
Reinellchris
Re: blue prints
if you use a long solid strait edge set to your height
then measure of every six inches using a combination square off your strait edge.then transfer your lay out and use a flexible piece of wood as a bat it will follow your curve.hope this helps
michael forbes
Re: blue prints
Saskatoon2005
Master Chief Petty Officer
Re: blue prints
Yeah, I agree,
use a chalk line and a tape measure...very easy to do, transfer to new wood and cut, and trim to fit if necessary...
iwombat
Re: blue prints
Or, if you want to go all high-tech on us . . .
Shoot a laser from one end to the other, then measure up to the laser dot. You just need one good flat spot on a stringer to set a laser on.
