Blue fin 1600 bass boat by spectrum
Bad boys 6
anyone know the capacity of the fuel tank?its a 1992 I recently bought and the owner did not know.Thanks Danny
fetch
gm280
Bad Boy 6, sorry but I tried my best to research your boat and I was unable to find the tank size. I did find tons of other info about it doing a simple "google" search though. Hopefully some other iboaters will chime in and say... Sorry! :facepalm:
JoLin
If there's an inspection/service plate on the deck above the fuel sender (there should be), pull it and look for the sticker on the tank that'll tell you how big it is.
Alumarine
If you can get at the tank and measure it, you can determine the capacity.
Bad boys 6
thanks jolin I will look , Thanks Mark c I know this but cannot do it with the flooring covering it Thanks to you both
roscoe
I had a slightly larger version of that boat, and tank was 12 gallons.
Bad boys 6
trouble steering on my 24 ft. sea ray at high sped it takes a hard right or left trowing us around without moving the steering it has power steering cant find the devil any ideas Thanks Bad boys 6
