Blowing Parking Trailer lamp fuses
Zero Balance
I have an 02 Suburban that keeps blowing TLR/parking lamp fuses.
When hooking up my trailer lights I noticed I had no running/tail lights. I did the usual check under the wiring receptacle as this was a nasty looking dealer install on the towing package. I find everything working except running lights. Next I chech the fuse. The fuse was blown. After changing the fuse (15a) I went under to the receptacle to find it smoldering/melting insulation (running/Parking lamp). It pretty much fried my 7:4 receptacle. I went down this morning and bought a new 7:4 receptacle and 7 way plug and all the trailer wire I'd need to rewire thinking I had a short in the trailer somewhere.
After hooking up my plug to the trailer wire harness, I checked continuity with the plug plugged into the receptacle (before it was installed) to be sure everything checked out. I ran my wiring on the trailer and hooked up my marker and tail lights. Again, everything works except the running/parking lights. I rechecked the fuse and it was blown. I replaced it, still nothing.
What I do have is this:
Yellow- Left Blinker/brake light / OK
Green- Right blinker brake light /OK
Purple _ Back-up light / OK
Brown- Running light xx No running lights....
I'm perplexed
Any help would be appreciated.
SpinnerBait_Nut
Re: Blowing Parking Trailer lamp fuses
Does it blow the fuse without being hooked up to the trailer?
Sounds like a short somewhere on the tow vehicle.
Zero Balance
No.... Tomorrow I'll drop the boat in the water for a bit and get a better look at things. My son was helping, Kaint git my fat arse under the trailer :p
He may have pinched a wire in a clip or something. Hard to believe lightning could strike twice in the same place though.
Zero Balance
Ended up being a short in the new over 80" lights. Just goes to show what the FTA gets us. Spent probably 10 hours chasing this gremlin....
What ever happened to American Made? :(
