Blowing Fuses
bman1bpm
P 0 P E Y E
Re: Blowing Fuses
Sounds like you have too much protection.....
Most horns draw more than 2 amps
Check the working load on the items and see if 2 and 4 amp fuses are too small.
Silvertip
Honorary Supreme Mariner
Re: Blowing Fuses
Yup -- too small a fuse on the horn for sure. The choke may be close but stilltoo small. If you used 16 gauge wire you could safely use a 7.5A fuse for testing purposes. If it holds, then leave it. If not, there is definitely a wiring issue.
bman1bpm
Re: Blowing Fuses
ah sounds good, thanks :). I just tried those two things and decided I better not try anything else till I figure out whats wrong. I'll try some bigger fuses.
