Blowing 15 amp fuse for gauges and ignition.
Eric Scammell
At the first of this summer I accidentally hooked up my battery terminals backwards. I had to change my 50amp main fuse, my started and my alternator. Now the only problem I'm seemed to be left with is I keep blowing a 15 amp fuse under my dash that runs the ignition switch and all my gauges. I've traced all the wires and they all look to be in good shaped. The fuse seems to always blow when I shifting the boat either from forward into neutral or vice versa. The boat is a 2001 bayliner 3.0L Mercruiser. Can anyone help me out here?
j_martin
Re: Blowing 15 amp fuse for gauges and ignition.
frayed wire inside the control housing, possibly smoked by the original charlie foxtrot.
NSBCraig
I'd start unpluging gauges and see whats popping it.
Breakers are a lot cooler than fuzes.
