blower question
dcjcdc
have a 1990 corsica sunbird 20 foot boat
- changing the blower as it it squealing
looks eay to change but noticed 2 wires that go to the blower....im thinking when i get the new blower it will have 2 connections for those wires
is this correct
thanks
spikeitaudi
Re: blower question
is this correct
thanks
Should just be a positive and negative wire.
seabob4
Re: blower question
That's it. Hot to the blower switch wire, ground to ground, piece of cake...
Fireman431
Re: blower question
More than likely you will have to cut and splice the wire. Most don't come with and quick-connect plug. But, this would be a great opportunity to add one.
Thad
Re: blower question
You need to splice the wires and use a good heat shrink over it. Be generous. The last thing you want when you turn on the blower to remove gas fumes is a spark from the splice.:eek: Kinda defeats the point of having a blower.:rolleyes:
It is, however, an easy task. See, I don't even call it a job. Now, if it were...:D
seabob4
Re: blower question
I don't know about that, sometimes blowers are installed in some godawful places...:mad:
Thad
Re: blower question
Yeah, now that I think of it, my Rinker blower was hard to get to. A new piece of vent hose and relocation was in order on that.:D
seabob4
Re: blower question
I mean, I work for a builder, and you wouldn't believe some of the locations we put them in...as if my boss thinks they'll run forever!
The interesting thing is, in my sidework, I find them exhibiting the same failure symptoms as the OP described. The shaft starts squealing, leave it go long enough and it binds up and trips the breaker...
rbh
Re: blower question
As bob said some blowers get put in the worst places, if yours is a bear to
re and re just put the new one in an easly acsessible point and extend the hoses.
