Several months ago my 130 hp Johnson 1996 goes in slow mode while retuning to port in very rough seas and heavy winds. No alarms or led lights came on. Continued running the engine in slow mode and after a few minutes it would go back to higher revs. Did this about three or four times over a course of 6 miles, I even used the kicker to try to maintain forward speed and control while heading into this heavy wind blown chop and 20-30 mph winds. We made it back to port and it took 2.5 hours on what normally takes me 40 minutes to come in even if the sea and wind conditions are rough for the last 6-7 miles. The engine would not start at wash down time. I decided that to take it in to the local dealer. The think the found the problem and replaced the power pack and the port temperature sensor, the one with the two leads.
At first the repair shop said that it was only the power pack, I okayed that repair and when they finally got the part and installed it they said that I needed another part which was the temperature sensor, the one with two leads.
Picked up the boat and took it out for a day of fishing, the engine did not go into slow but was idling very rough so took it back the next morning for an adjustment which was a quick in and out visit.
The motor went into slow mode again once only on another fishing trip a month or two later, but it came out of slow mode so I did not take it back in to get checked.
This past week, First week in March 2011, once again on the return trip to port from 14 miles up we encounter a smaller chop and winds only up to 20mph, but the engine goes into slow mode. I run with it this way and then it dies and I have to use the kicker to get back under way. After 10 to 15 minutes the engine starts can go back to high revs. We continue to the harbor with the main engine and the kicker going. Once again no alarms or warning lights.
Took the boat out again the next day to try and get in on the last couple of days that bottom fishing season is open. 4.5 miles out and traveling at 4500 rpm the engine goes into slow mode again. The next day the Japanese Tsunami hits. After a few minutes the engine works again and we turn aroung and end our fishing trip. Since it?s the end of bottom fishing I will not use the boat again until September 1, 2011, and I have the time to look for the problem myself.
These are the steps that I took looking for my problem. I tested the old temperature sensor that the dealer took out and it worked. Put it in a pot of water and connected a test meter. When the water got hot enough it worked. So one of the questions that came up was why did the dealer need to change this in order to solve my engine problem four months ago? I proceeded to take out the two temperature sensors in the motor and test them, they worked. I took apart the thermostats and tested them and they also worked, also looking into the housings there were clear passages and no build up of salt or hard water scale.
I replaced the impeller on the water pump last year and the pee stream is strong and when the engine is running the temperature was cool enough to have it run over my hand.
I next tested the brown leads on the temperature sensors and shorted them to ground and they lit up the warning light on the instrument panel, but no alarm or horn sounded. When you turn on the key the warning horn goes off and the leds come on and then goes off in sequence.
I removed the oil tank and dis-connected the four prong connector and found that connector in the bottom of the cowling covered with an oil slick and green stuff on the prongs. The brown lead when you short it out would light the oil led. I did not know that this connector was sometimes underwater (salt water that gets into this area). So I need to waterproof the end of this connector and keep it tied off the bottom of the cowling. Today I also notice another two wire item that has open ends sitting at the bottom of the cowling. I will remove the cowling and see where that goes.
I read in your treads about the blocking diodes and finally after looking up the part from one of the online parts supplier I found out that they are located in the wiring harness. The manual has a test procedure for these diodes and I preformed the test and found one was defective. Ordered one from a dealer on Oahu and should get it in a couple of days, and then I will install it.
Questions I need help with.
When the temp lights go off should the alarm also go off?
Can a power pack be tested to find out if it is defective or not. I have the one that the dealer took off that I believe works and that he replaced the one on the engine because that was probably a good guess to solve the trouble, but then after they install it they say that I need a temp switch in order to get it running, makes me question their skill or are they just replacing parts until they get it right.
Any opinions if I have any recourse against the dealer?
Any other suggustion on what my problem might be?
