Black tar/soot dripping out
t_andersen
Hi guys,
Here is a newbee question that may be simple to many of you. I have a 4 hp 1997 Evinrude that I use for my small fishing boat on a lake in Sweden. I use it only for 5-10 trips per season. I have had it serviced every year by a pro, but he charges over 200$ for the job, and I am a mechanical engineer, so I thought that I would save the money and plan to do the job myself from now on. I have bought an original manual for the outboard motor, I have all of the tools, and I am used to repairing and servicing my chain saws, so I should be capable of fixing it myself in the future.
Now here's the question: This winter and spring, the motor has been dripping a little bit. Not much, just enough to produce a black spot of what looks like tar on the floor under the motor. I do not believe that it is gear-case oil, it looks to me that it is more like soot from the exhaust. I have not seen it before, i.e. in the period 1997-2006. Is it a sign of something bad? Should I take any action?
Thankful for any advice-
Regards
Tom
tashasdaddy
Re: Black tar/soot dripping out
actually, very normal, it leftover's from the season before in the exhaust housing. it wants to be used more.
It is normal for it to do it, put a newspaper under it or shallow pan to catch it. It is exhaust junk. And if I am wrong I know it will be addressed. Real good forum. Ken
Carbon and byproducts of combustion (or stuff that doesn't get burned) builds up in two-stroke engines. There is a decarbonizing process outlined in several of the FAQ's. Search on the term "decarb". Treat your engine to that process and then give it a good thrashing for an hour or so to clean out these deposits. Your motor will thank you for it. The cleaning agent is generally a product called Sea Foam or Deep Creep. Mercury, Yamaha, and Evinrude/Johnson distributors also have their own brands of engine tuner. Treat your chain saw and other two stroke engines to the same treatment. It's like having a mechanic in a can.
t_andersen
thanks guys, this is a wonderful site. I don't know how we survived before the Internet came around. Regarding the latter remark, I did in fact do a decarb two years ago, I remember the thick, white smoke quite well!
