rejesterd
Thread starter- Joined
- Sep 20, 2018
- 142
I have a 2011 Yamaha F50 TLR.
Yesterday I was doing my routine spring maintenance to get the boat ready for the season. I went to change the on-engine fuel filter, and found a good amount of black particles in the filter cup. After I emptied the cup, I pumped some fuel out of the filter assembly cap (which I left attached to the inlet fuel line) with the primer bulb.. a significant amount of more black particles came out. So it doesn't look like it was just a tiny amount that had slowly built up in the cup. It basically looks like a fine black powder.. it's not clumpy, and I saw no water in the fuel.
I'm looking for guidance on how to determine the source of this contamination. I'm not sure if the black stuff is coming from the lines on the engine, the lines between the engine and the fuel tank, or from the tank itself. I'm going to take a closer look on Saturday. For reference, I have (what appears to be) a fiberglass fuel tank and a 10-micron fuel/water separator filter in between the tank and the engine (which was replaced last fall when I was winterizing it). Like every year, the boat sits from mid-September to mid-May. As part of my winterization process, I fill the fuel tank 7/8 full of E10 fuel and add Yamaha fuel stabilizer. I've used only E10 fuel since I've had the boat, but this is the first year I've seen black particles like this.
My current plan is to hook up a new primer bulb assembly directly to my boat's fuel tank, and pump out some fuel into a clear container. If black particles come out, then I would assume the tank is the source of my problem. If no black particles come out of the tank, then I'm going to hook the other end of my spare bulb assembly line directly to the engine. Then pump the bulb and see if the black particles stop coming out of the on-board fuel filter assembly cap. If they stop coming out, I think I can assume that the particles are due to rotting fuel lines between the fuel tank and the engine (and I'll simply replace them). If they don't stop coming out at that point, I think I can assume that the fuel lines on the engine itself are rotting. I suppose that could be due to using E10 fuel. However, the owner's manual says that the engine is calibrated to handle E10 fuel. I assume that means the engine lines are rated to handle a small percentage of ethanol.
Once I find the source of the contamination, I will inspect the mechanical fuel pump and drain the vapor separator to see if the black particles made their way in there. If I find black particles in there, I will get the rebuild kit for the VST and monitor performance on the water after rebuilding the VST. If performance still suffers, and I go back and confirm that no more black particles are coming in, I'll send the injectors to be cleaned.
Does that sound like a reasonable strategy?
Thanks.
Thanks.
