jdlough
Master Chief Petty Officer
Thread starter- Joined
- Jul 15, 2006
- 824
I got the kids a 16' Wahoo skiff. I'm about to put in a bilge pump.
I'm concerned that with an automatic pump pumping out the rain water, it may drain the battery.
If it does drain the battery a bit, but the battery is good enough to start the motor, will the motor immediately begin to start recharging the battery enough that if they cut off the motor out in the bay five minutes later, they will have enough juice to restart the motor?
Should I install the pump with ONLY a manual switch?
Jim
Jim
