Bilge Pump Replacement - 1988 Bayliner Capri
I am worried that I abused my bilge pump “pad” when I put screws in it. As you can rightly guess, I am a rookie at all of this.
The old pump was shot, so I wired in a new one with the float switch in it. It was a serious ordeal to reach back there, using a mirror to see what I was doing. I mounted the new one on the same pad that the old one was on, reusing two of the three original screws. I got one in the old hole, and had to make a new hole for the second one. I drilled a pilot hole for it, no deeper than the length of the screw. I just couldn’t puncture the surface with the screw itself, or at least not at that awkward angle. With two screws in, I called it good and did not do a third.
How reckless was I to drill that pilot hole? I didn’t put much of any downward pressure as I drilled, and I stopped when I broke through and the bit sank about the depth of the screw. Did potentially hit something I shouldn’t have? And how bad was it to not use any sealer for the old holes or new ones? I could see that the pad was a designated spot for the pump to go, made thicker so I didn’t have to drill into the hull. But am I now looking at rot if I do not dry it out and redo this with sealer?
The new pump works like a charm, and I think in the future I will put the whole thing on a big 90 degree piece of stainless steel that I can attach on the side and easily remove.
jerryjerry05
That pad is a glassed in piece of fiberglass.
Shouldn't rot, ever!!
Lots of people use silicone to mount a pump and switch.
Just make sure the base is dry.
Oh yea wrong forum, you need the first thread in the forum.
I've worked on hundreds of Bayliners all makes and sizes. Tech at Stammers Marine Center, Sold thousands of Bayliners.
This is a huge relief, thank you! So it’s also not likely that I went to far and compromised the hull?
Very cool that you put your experience toward community service.
