INJUN
Thread starter- Joined
- Apr 29, 2008
- 358
I once had a RULE pump with a separate float switch along side of it. When I wanted to be sure that it worked, before leaving it for the week, all I had to do was to raise the float switch arm momentarily and listen for the pump motor to start. The boat was open at the transum, so the pump was easy to access.
I'm considering getting a Rule pump with an automatic (internal) switch.
Question: How can you test this type of pump for reassurance as I did with the separate float switch?
Thanks.
Thanks.
