Bilge pump problem
Darol Wester
I'm not sure this is in the right catagory but here goes,
I was testing my B/pump and noticed that it runs but doesn't pump, until I take the hose off a little bit, then it takes off great. Could this be caused by a primming problem or might it be time for a new pump? I don't know the brand, but it is yellow and maybe 4" in diameter. If need be, I'll take it out and see.
Don S
Re: Bilge pump problem
I would say it's probably time for a new pump. When you have to play games to get them to prime, they are junk. Get a good quality pump, (not the cheeeeeeeepies) unless you know how to walk on water.
Darol Wester
What's a good one Don? Looking at this one, I'm curious if you think this is a good way to go or should I stick with the float switch?
Rule 500 (25S) Automatic
Price: $51.99
Manufacturer: Rule
Product Details:
Rule Automatic Bilge Pumps
Float switches are not required for these fully automatic pumps. Controlled by computerised operation, the pump will turn on every 2.5 minutes for about 1 second to sense for water. If water is present, the pump will sense resistance and continue to run until all water is removed. Power use in the checking mode is minimal for the peace of mind that this range of pumps offer.
The Rule 500 offers many design features while keeping size and cost to a minimum. Especially popular on smaller craft, Rule 500 pumps are unmatched in pumping power and longevity. 3/4’’ (19mm) discharge outlet. Note: 25D pictured.
Automatic 12v
Specifications:
Voltage: 12 Vdc
Amp Draw: 1.9 amp
Fuse Size: 2.5 amp
Height: 4 inches 102 mm
Width: 2 3/8 Inches 60.3 mm
Weight: 11 oz 310 g
Darol Wester
Fortunately I didn't buy a new pump. As I always do when something fails, I like take it apart to find out why. What I found was the nut that holds the impeller on had fallen off and probably when out the discharge. It caused the impeller to drop down a bit, but just enough that it wouldn't allow it to prime. I put another nut on with locktite and she works like a dream.
Gotta love it. :)
