jurgenscraft
Thread starter- Joined
- Nov 6, 2004
- 227
The boat I have consists of the hull having 4 seperate compartments each interconnected by a 25mm hole drilled through each compartments allowing water to flow through to the drain plugs at the back of the boat, each compartment is fitted with a hatch so as to gain access, and for general inspections of the hull from the inside, <br />The question I need to ask is "where should I mount the bilge pump" (front, middle, rear)<br />kind regads.<br />William Wright.<br /><br />n
