Bilge Blower Air Flow
jfb
I am replacing the bilge blower on my used I/O. 1) The existing blower has the fresh air flow INTO the bilge. The new blower's directions show the contaminated air flow OUT FROM the bilge. <br />2) The boat has one blower, I am thinking of putting two blowers in. One exhaust on each side (Port / Star) of the tramsom. Any thoughts?
rml
Re: Bilge Blower Air Flow
jfb --<br /><br />1. install the new blower per the manufacturers recommendation, with the air flow OUT -- sounds like you're planning on doing that.<br /><br />2. 3" blowers tend to move quite a bit of air (~150 CFM) and the 4" units move a LOT of air (200+ CFM). I personally can't see why you would want to install two, although having a spare on hand isn't a bad idea.<br /><br />Anyway, nice to see yet another Mainah out here -- welcome to the iboats forums.<br /><br /> --rml
Yep.....<br />Install the new 1 blowing Out, drawing from a Low Point in the Bilge.......
beezee28
Master Chief Petty Officer
Like rml said, why would you need 2 blower? 1 is ample and the flow of air should be going out. Good luck.<br /><br /><br />"Knowing is not enough; we must apply. Willing is not enough; we must do."
MrBill
Yes, install to blow out and locate end in lower point in bilge, but not too low or you be sucking up bilge juice.
