greasemonkeyjmj
Thread starter- Joined
- Jul 7, 2008
- 264
i have a bomber 15 foot fiberglass bassboat. the bilge is routed with a thru hull fitting, going through the transom. i am having problems with water backflowing into the thru hull and collecting in my bilge area. i have tried looping the hose and routing it as high as i can . i also went to the home improvement store and picked up a 3/4 pvc check valve. the only problem is, with the valve in place, the pump is not stout enough to push the water out through the valve. as always info is appreciated
