Eric Moore
Thread starter- Joined
- Aug 24, 2015
- 5
I have a 1964 big twin 40 hp model # 40452 S when I first bought it the motor it ran great however the transmission would not shift into forward so I pulled the motor off and replaced the cradle and clutch dog. So while I had it off I went through the whole thing rebuilding the fuel pump, carburetor, replaced the impeller , coils points and condensers,plug wires, head gasket, thermostat, and of course plugs. now with the motor in the bucket and prop off it seemed to run great but once in the lake it was a little hard to start and the motor would not get up to speed ( low power) the boat would move around at about 10 MPH. The engine did idle extremely smooth and what rpm it did make sounded good no back firing, sputtering, or cutting out. Now in between the time the engine ran great and me rebuilding every thing I did fill the gas tank I put in the oil then the gas but I I thought the tank was empty when in fact there was still about a gallon of gas in it. so I mixed the gas to rich. So question 1. Would a to rich fuel mix cause the engine to foul enough so it would not get up to speed?
and my 2nd question is concerning the throttle control cam lever and pin assembly rod and cam. The lever and pin is connected to the magneto group through what I am guessing is a mechanical advance. The rod is connected to the lever and pin assembly which goes back to the carb, and cam (little wheel thing) the cam roles on the throttle cam. While I get the concept I am guessing on how to adjust it all together could some one please help me with this. Thank you for any help you can give me
