jmarty10
Thread starter- Joined
- Aug 6, 2007
- 560
Here is my setup:
1. 2008 Larson 180 - 18 foot fibergalss i/o witha 4.3l 190 hp TKS, alpha one. Dry weight= 2300lbs
2. Running a factory mercury alum prop that is 14-1/4 x 23p prop
3. WOT with about 650 lbs aboard = 4700 rpm going about 47 mph
I have been pretty satisified with the performance as prop stays in RPM and speed range. My question is? I have a couple of old 14X17p alum props from the old boat. What will be the effect in dropping the pitch by this much? I have been considering getting a 4 blader to help with hole shot when tubing and staying on plane longer. Will the 17p do this. Also, given the above what pitch is recommended on my rig when going to a 4 blader?
