I have a 1995 Seaswirl 185E; the original owner upgraded the motor option from the 4.3liter to larger heavier 5.0 liter. I was wondering if there is anything that can be done to add stern buoyancy without compromising performance and handling.
use a hole saw and cut holes in some inconspicuous places (under seat bases etc)How would I check for soggy foam.
You could take off about 70lbs on the engine by going to aluminum heads and probably another 10 by switching to an aluminum intake manifold (if not already done). Aluminum water pumps are fairly cheap and will shave some weight.
