Alternator is working as you get a glow in the oil warning light when you pull the starter cord. Checked the kill switch and that's working OK. Tried to check the ignition coil but I don't know how it works as there only seems to be one low tension wire. The high tension leads seem to be sealed into the coil so I can't check the resistance of the ht side of the coil. Resistance measured between the single terminal and the engine casing was 0.9 ohms, which seems low to me
I could not see where the magnetic ignition sensor lives so could not check that. Is there any information available online for these engines?
