BF25A Which cable is positive?
chechr
Hi,
I had the battery connections replaced on my 2001 BF25A cables, and now that I look at them I can't tell which is positive. The double cable is coming straight out of the engine and one side has a white stripe running along it. Is this the positive cable?
Thanks,
Chris
pvanv
Re: BF25A Which cable is positive?
Yes. Negative ground. To verify, trace down the wires inside the cowl. The unstriped wire should connect to the block.
chechr
Yup, thanks for the answer. Had a great day on the water.
