Re: best wood for transom replace
Lots of the Tin Boat guys on here use the Arauco Plywood from Lowe's or Home Depot. Floor Underlayment is also good. Both use waterproof glue and are practically void free in their laminates. Key on transoms is to seal the edges really well. On a Tin Boat Transom I'd recommend using Epoxy as your resin. No need for Cloth when using it. After that maintenance is the key. Whenever you need to tap into the transom, Always predrill and coat the holes and the bolts or screws with epoxy when installing. This will ensure no water gets to the wood.
