Best Way To Remove Oil Seals?
Captain Caveman
I've been tearing apart a 3hp 1957 Johnson Seahorse. I replaced the oil seal between the gear case and the drive shaft (just below the impeller). It was a real pain to remove and required lots of different attempts with various tools. I was thinking about replacing the one in the gearcase as long as I've got the gearcase pulled apart. Is there a good way to remove these semi-easily, or just pound and pull?
nwcove
Re: Best Way To Remove Oil Seals?
a seal puller tool helps destroy the seal as bad as any method!!but patience and creativity with the tools you have will usually work.
Captain Caveman
A seal puller....sounds quite logical!
boobie
Check with Harbor Freight or any parts house as there are different seal pullers.
