Re: Best Way to Remove a Hook From Your Person?
YEAH, NU , i know the procejure you want but it's impossible to write to words . i saw FISH FISHBURN, one time on his fishin' show .. he IS hands down the most flat- out funniest/ silliest sob i ever seen.. he's a NUT !! he took a treble hook lure an willfully sunk it in his hand to demminstrate how to remove it.. i wish i saw the show again cause i was to busy rollin' on the floor laughin' .. I FELL OUT !! you take a loop of fishin' line ( i have one already made up just in case) loop the loop over the hook than loop the loop over somthing hard mounted like a boat cleat .. what it essentialily is ,is like you have a loop of string ,stick both thumbs inside the circle an pull apart ( opposing pressure ) tite.. so far seems like an said alotta words to explain sometin' so simple.. so don't read complication into it.. so now with one end of loop around the hook ( an it will be naturally at the hook & skin junction.. the other end/ side of the same loop ( or you mite want to think HOOP INSTEAD OF LOOP ) is around an anchor point like a boat cleat... an pull back to cause painful pressure .. in doing this the shank of the hook is raise off your skin , say at a 20 % angle... press down on the E Y E of the hook,,,,, & BINGO out comes the hook .. try it on an orange ... it's a good sub for skin ... WHEWWW !! I'M TRIED & PECKIN' FINGERS KLLIN' ME .. hope you can make sense of it ... good luck... p.s. if it's a treble lure cut hook from lure the snip off the other 2 hooks to make a single hook...
